-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Small crack (2.5in) in mirror by light fixture (http://www.diychatroom.com/f80/small-crack-2-5in-mirror-light-fixture-174796/)
dmannne 03-17-2013 06:08 PM
While installing the second of two floating light fixtures on a new bathroom mirror a small crack suddenly appeared. I thought i was being very careful and just barely finger tightening it as i had on the first one. It 's only 2 inches long but noticeable. Is there any way to fix it or am i looking at replacing.
joecaption 03-17-2013 10:13 PM
There is no fixing it and there's a real danger it may just shatter. Get it out before someone get cut.
sgjordan 03-23-2013 09:50 PM
If it runs to the end of the mirror, it has run. If the crack ends inside the mirror, it will run at some point. Pressure, vibration, and heat are a few things that can make it run. So basically the mirror will break at some point. If you're gonna remove the mirror, run the crack first. Or have a pro do it. When installing a light fixture on a mirror, you should shim the fixture out. It's best not to have it resting on the mirror.
