Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-02-2013, 04:16 PM   #16
MJ Force's Avatar
Small concrete countertop-can it be cantilevered?
More pictures.
MJ Force is offline   Reply With Quote
Old 01-02-2013, 04:26 PM   #17
MJ Force's Avatar
Just remember that it was the thickness 3" and the rebar and mesh that allowed me to cantilever this hearth. It is strong and the large L-Brackets at the rear allow me to stand on the edge with no worries.
Old 01-02-2013, 04:57 PM   #18
Nice technique-I'm definitely going to be upping the thickness of my slab to 3". I was planning on casting mine upside down and I had a thought. It might make for an interesting stone like texture if I spread sand in the form and made it a bit uneven and then put poly over that-I could even incorporate lines using wire like you did as well. Lots of possibilities...
Badfish740 is offline   Reply With Quote
Old 01-02-2013, 07:06 PM   #19
MJ Force's Avatar
After the hearth had cured (2-4weeks) I applied an acid wash then stained with a charcoal colour. I finished that with a clear gloss finish. I suppose you could experiment with pigments for concrete but I needed a specific colour which is why I used a stain.
Old 01-02-2013, 10:02 PM   #20
Made a template from 3/4" plywood and tested the fit:
I'll eventually cut the piece down and use it as an underlayment for extra support.
Concrete Countertop Overlay jseymour186 Building & Construction 3 10-18-2011 05:29 AM
12"x12" Tile Layout on SMALL (15"x24") Countertop? mirzai_m Kitchen & Bath Remodeling 6 01-11-2010 01:28 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
small cracks in PT sole plates on concrete amakarevic Building & Construction 14 07-23-2008 02:48 PM
patching small holes in concrete amakarevic Building & Construction 9 07-23-2008 01:37 PM
