Sink Base - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 10:32 PM   #1
Rewards Points: 168
sink base
should the kitchen sink base be as wide as the window it is under ?
Fix'n it is online now   Reply With Quote
Old 08-21-2013, 07:18 AM   #2
DIY staff
Rewards Points: 7,174
Width does not matter==centered to the window is best=====
Old 08-21-2013, 09:30 PM   #3
Rewards Points: 168
yeah, i spose it doesn't. but it seems to me that if the base was about the same width as the window, it would look more uniform.
Old 08-21-2013, 10:35 PM   #4
DIY staff
Perhaps it would,but I've never had anyone bring that up as an issue.---Many windows are rather narrow above the sink--so that would mean not enough room for the sink----
Old 08-21-2013, 11:11 PM   #5
Rewards Points: 168
well. i guess then, my window is rather wide. about 44". i wanted a nice view of my back yard. plus let more light in.
the reason i asked = i didn't know if they made base cabs that wide. but now i know they they make em up to 60".
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (08-22-2013)
Old 08-22-2013, 11:27 AM   #6
K&B Designer
Live_Oak's Avatar
Sink bases are the most waste of space in a kitchen. You want a base just large enough to hold your sink and no wasted space. Use the additional space to make the adjacent cabinets larger. That creates a better use of space, especially in a small kitchen where space is precious. So, for your 44" of space, you'd do a 36" sink base if you're using a standard 33" sink, and try to get that 8" into other usable space.
Live_Oak is offline   Reply With Quote
sink drain exterior wall iskyfly Plumbing 11 02-04-2012 07:38 PM
Granite Sink Leaking ptfrost Plumbing 5 10-04-2011 07:51 AM
Stainless Steel Sink Question jamiedolan Remodeling 3 05-01-2011 08:35 AM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Sink gasping water Filbee Plumbing 7 10-23-2009 11:36 AM
