Simple Countertop Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 09:29 AM   #1
A Little Of Everything
Rewards Points: 1,364
Hey All -
I'm going to be installing new countertops for some family members this evening. Pretty straight-forward job. One corner & two straight pieces.
It has been awhile since I've done countertops, and I don't remember what I did last time. Also, I didn't find anything through searching the forum.
My question: Should I just clamp the mitered ends together dry, or run some wood glue in their first? Something else? Silicone?
Thanks!
DrHicks is offline   Reply With Quote
Old 09-15-2011, 11:06 AM   #2
Civil Engineer
Rewards Points: 4,778
Are these granite countertops, laminate, formica, silestone, wood? The proper way to attach a miter varies with the type of surface.
Old 09-15-2011, 12:22 PM   #3
I'm sorry. They're just your basic laminate countertops. From Menards, actually.
Old 09-15-2011, 04:14 PM   #4
Civil Engineer
OK, so you have laminate (formica) pre-made counter top, and you want to connect two sections at a 90 degree angle. I assume the substrate is particle board, or possibly OSB. Personally I would use a couple of 00 biscuits and waterproof glue at each joint. There will obviously be a seam there, but you knew that going in, and I guess everyone is OK with a seam, so have at it.
Simple question I can't find the answer to Richo Plumbing 7 07-17-2011 10:20 AM
Simple bathtub question joebann Plumbing 3 09-11-2010 07:47 PM
Simple question tamar120 HVAC 1 05-10-2010 06:06 AM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
