Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-26-2010, 07:32 PM   #1
Shower Window Sill
Hi all, i just moved into out new house and i noticed alot of water sitting on the shower window sill in the bathroom,its tile and flat. i dont trust the previous owner and his DIY skiils and im looking for suggestions on how to improve this window sill from becoming a problem down the road.Shower Window Sill-dsc05732.jpg
cnick is offline   Reply With Quote
Old 11-26-2010, 08:03 PM   #2
Shower Window Sill
The problem is that the PO left it horizontal. It should have sloped down somewhat. I don't know what your best solution is there. One thing that comes to my mind is possibly you could silicone down a solid piece of surface material over the top of those tiles in the window sill. Even if it is still flat, there would be less risk of water intrusion. Or, you can towel this area dry after showers. Short of getting into some retile work, those are the best solutions I can come up with.
Jim F is online now   Reply With Quote
Old 11-26-2010, 08:22 PM   #3
Super Moderator
Shower Window Sill
Jims solution sounds good--Solid surface materials like Corian can be worked with ordinary woodworking tools.
Getting some pitch in that area might mean removing the cap tiles or beveling the Corian on the back side.
Old 11-26-2010, 10:00 PM   #4
Ultimatetouch
Shower Window Sill
Agree with Jim. Always use solid materials for sills and for the tops of shower bases. Anything else is not quality workmanship while remodeling a bathroom.
_________________
Ultimatetouch
Bathroom Remodeling by an Illinois Remodeling Company
ultimatetouch is offline   Reply With Quote
window sill repair from inside the house joshg3p0 Carpentry 3 06-10-2010 08:07 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 09:34 PM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 10:24 PM
Shower window issue help! Ducowti Building & Construction 2 05-26-2005 04:36 AM
