Shower Wall Waterproofing - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 04:51 PM   #1
shower wall waterproofing
Hello,
So I'm adding a bathroom in my basement. I'll be doing an all tiled shower. I just finished the preslopre by following this great article http://www.ontariotile.com/preslope.html
now it's time to add the backer/cement board and liner. My concern is, how do I waterproof the walls? I've talked to HD guys and they say just add a 4-6mm plastic, staple it on the studs and put your cement board. This shower will not be heavily used, in fact, it'll be rarely used but I want to do it right but at the same time I don't want to spend too much money. can anyone help me with some proper procedure for a reasonable cost?
Thanks.
kimbhoot is offline   Reply With Quote
Old 10-23-2013, 05:45 AM   #2
DIY staff
Rewards Points: 7,174
I would suggest a paint on surface membrane --Redguard is about $50 for enough to do a typical shower----with that, you do not need a plastic vapor barrier behind the backer board----
tribe_fan (03-05-2014)
Old 10-23-2013, 09:37 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Ditto what Mike said.
The Following User Says Thank You to Blondesense For This Useful Post:
oh'mike (10-23-2013)
Old 11-25-2013, 02:34 PM   #4
pan liner issue
I bought one of those pre-cut pan liners (5'x6'). They have it folded in a bag.. after installing it, seems like there are few kinks and folds that won't completely flatten! I've already installed the backer board and having trouble getting the liner lay flat completely. I did a water test and the water is having trouble draining down because of those kinks.
what suggestions do you have? when I make the shower floor, I can push it hard and make them stay flat! hopefully that will work. not sure if you guys have any other suggestions!
Thanks.
Old 11-25-2013, 02:47 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Red guard is the easiest. Just roll it on. Concerning your second question. I don't have a clue about a fold up water pan. The only ones i know of. The Styrofoam ones made by Schluter or you go old school mud job.
I sure one of the other guys have seen the one you purchased.
747 is offline   Reply With Quote
Old 11-25-2013, 02:49 PM   #6
iminaquagmire's Avatar
Rewards Points: 338
Some heat might let you massage the wrinkles out. But my concern is that you say you already installed the backer board. Is there a vapor barrier behind the backer board? How does everything meet the pan liner at the bottom? Do you have some pictures you could post so we can see what you have done so far?
iminaquagmire is offline   Reply With Quote
Old 11-25-2013, 04:08 PM   #7
DIY staff
Wait---you did install the liner before you put up the backer board,right?
Old 11-25-2013, 11:28 PM   #8
backer board went after the liner
watch this.
http://www.youtube.com/watch?v=1M76r...ature=youtu.be
Please let me know what to do with the extra liner.. I was thinking of taking that one backer board off and pull the liner up a bit.
Old 11-26-2013, 05:32 AM   #9
DIY staff
That video shows some excess fabric, but I think the deck mud will work fine over that----You are there ,so you must make the call---
I suggest you do a flood test before packing the pan----it's good insurance---fixing a leaker is cheap and easy now--after the pan is packed and tiled? Not so simple.
Old 11-26-2013, 10:05 AM   #10
while I'm packing the mud, I think I can push the fabric outward and make it work.
I did do a flood test. just cut 4 notches to get the bolts out, added the top drain flange upside down.. didn't leave the water overnight tho. and had trouble draining the water because of the excess fabric.
Anyhow, if I can get the mud push the fabric down, I think I'll be alright.
Old 11-26-2013, 06:28 PM   #11
DIY staff
I think you will,too. Keep the mud on the dry side---just like the instructions in the link you posted.
Old 03-05-2014, 04:23 PM   #12
Ditto again what Mike said above about paint on surface membranes.
If you don't go with the RedGuard, then I would recommend Laticrete's Hydro Barrier. You can apply it with a brush or roller, but you will get better results spreading it with a joint compound knife. Remember to tape the seams with a fabric or fiberglass mat tape. When they dry they conform to the surface of the board thus leaving NO bumps for the tiler. Laticrete also offers a product called Hydro Ban that I hear eliminates the need to tape. Just another option for you.
DIYRemodeler is offline   Reply With Quote
The Following User Says Thank You to DIYRemodeler For This Useful Post:
oh'mike (03-05-2014)
Waterproofing tiled shower walls. Blondesense How To Guides 22 06-06-2014 01:29 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
bathroom shower in basement along foundation wall jeeper Building & Construction 1 04-16-2009 07:20 PM
wobbly shower wall red86yota Building & Construction 5 02-25-2009 11:02 AM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 04:13 PM
