Shower Wall Water Infiltration: Will Dehumidifier Help? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 03:07 PM   #1
Shower wall water infiltration: Will dehumidifier help?
Hi,
One of the shower stalls in the apartment/condo was inspected by the home inspector and mentioned to have "water infiltration" (measured by the moister meter) behind the wall's ceramic tiles. He mentioned that water has probably dampened the wall behind the ceramic tiles, since the grout wasn't properly sealed.
Will it be possible to fix this by putting a heavy-duty dehumidifier + fan inside the shower stall for a week or so? Then seal the grout to prevent any additional water from penetrating behind the tiles.
shababak is offline   Reply With Quote
Old 09-14-2009, 04:08 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
There are several problems here. 1). If the walls are truly damp behind the tiles, they may have already been damaged depending on the wall construction. 2). Running a dehimidifier will take forever to dry out anything behind the tiles. Drying out walls involves forcing dry air into the wall to drive moist air out. The equipment to do this is very specialized. 3). Did the inspector use a probing type meter to investigate, or a surface type meter? Surface type meters are not very rteliable on tile walls. Grout can hold moisture from the last time the shower was used and give a false reading. Also certain tiles contain oxides in the pigments that can fool a surface reading meter. Someone testing tiles with a surface reading meter needs to be very careful with their technique. I've actually witnessed guys taking high readings on tile walls that were absolutely dry when measured on the backside of the wallboard. If possible, access the wall cavity and inspect and test from the back side.
Old 09-14-2009, 04:37 PM   #3
The inspector used a surface type meter. And I recall seeing that the shower was used earlier that morning by the tenants.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
New shower valve.. No water pressure? wilson5307 Plumbing 2 03-11-2009 11:10 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
How to know if shower wall plumbing is leaking? dolvio Plumbing 3 10-27-2008 07:11 PM
