Shower/tub Surround Wall Falling Down?? Possible Mold? HELP! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 12:39 AM   #1
Exclamation
Shower/tub surround wall falling down?? possible mold? HELP!
We just bought a house and the shower/tub surround is falling down on the back (the longest) wall. I am pretty sure it is a 3 piece wall system. I have no clue about any of this! I have a pic of the bathroom...its not the best pic but its all I have right now. ANY ADVICE is MUCH appreciated!!! I don't know if we should attempt to fix it and I have no clue how to do that! OR should we tear it all down to check for MOLD?!! thanks!!!
Shower/tub surround wall falling down?? possible mold? HELP!-dsc_8338.jpg
Port Hudson is offline   Reply With Quote
Old 06-24-2012, 06:38 AM   #2
DIY staff
Rewards Points: 7,174
What is the surround made of?
If it's leaking and shows signs of coming loose from the wall--You need to remove it and see what's going on.
It might be possible to remove and reinstall--but don't count on that--depending on the material--
it might break during the removal ---
More info needed--
Old 06-27-2012, 01:49 AM   #3
More pictures
We got to go to the house today so I was able to get a picture of the gap off the wall. I think the shower walls are made of fiberglass. I am not sure if much water could have made its way into the gap from the positioning of the shower head... but it still kinda makes me nervous.
Would re-gluing the wall and fixing the gap end the mold problem IF it were to exist where it can't be seen?
Thanks!
Shower/tub surround wall falling down?? possible mold? HELP!-dsc_9216.jpg   Shower/tub surround wall falling down?? possible mold? HELP!-dsc_9217.jpg   Shower/tub surround wall falling down?? possible mold? HELP!-dsc_9224.jpg
Old 06-27-2012, 05:21 AM   #4
DIY staff
That could easily be re glued---use PL premium .
A couple of 1x2s or 2x2s wedged to the opposite wall will hold thw sheet tight while the glue driees--not a big job at all---
--Mike---
Port Hudson (06-29-2012)
Old 06-28-2012, 12:48 PM   #5
Great Thanks! .... now what about...
Great! Thanks! Now what about.... the shower walls. can the shower walls be painted? I am not a huge fan of the design... I am wondering if we can paint them or even cut a 5 inch stripe horizontally out of the walls and tile in them to make them look more custom. I attached an example pic below of the stripe across the walls. We would then also tile up to the ceiling above the walls.
what are your thoughts?! :D
Shower/tub surround wall falling down?? possible mold? HELP!-tile-shower-wall-example.jpg
Old 06-28-2012, 02:33 PM   #6
AGWhitehouse's Avatar
If you don't like the look, rip them down and start over. If they are really fiberglass, as you suggested, you can't do much with them besides that.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 06-28-2012, 02:58 PM   #7
Renovations contractor
Bonzai's Avatar
As he said, if you want to do it properly then time to start over. Usually those acrylic / glass fibre tub/shower surrounds come out pretty easily if you have the right tools and know what you're doing.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
The Following User Says Thank You to Bonzai For This Useful Post:
Mold in bathroom exterior wall Chemist1961 Building & Construction 11 07-05-2011 11:22 AM
Mold found - unsure what to do?? izzyant88 General DIY Discussions 12 06-17-2011 06:21 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Mold on framing of bathroom wall CowboyAndy Remodeling 34 10-22-2010 06:53 AM
water damage to exterior wall with rot and mold bjoldham Building & Construction 10 08-12-2009 05:48 PM
