Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-22-2011, 01:49 PM   #1
Question
Shower pre-slope and pan questions
I am converting a tub to shower and have a few questions....
PLAN
slip sheet , wire mesh w/ mud for pre-slope & Red guard for pan. Backer board on walls w/ niches (not prefab) and a Better bench. 4x4x16 cmu w/ 2" cap for curb.
QUESTIONS
* re: mesh for pre-slope- Can i use "hardware cloth" 19 gauge 1/2" mesh w/ galvanized zinc coating?
*after pre-slope is constructed should i put the Redguard on (as pan) then the cmu cap and proceed with the mud for shower floor?
*should I use lathe on curb?
*does the mud on curb need to be 3/4" thick on all sides? ( i am trying to calculate the space between the existing saltillo & CMU for the curb to allow for all phases and a grout joint)
*should I Redguard the studs around & behind the niches before i put the backer board in it? Then red guard the niche again?
*one last question, how much Redguard should i need? i bought a 1 gallon bucket and a 3.5 gallon bucket.
I would appreciate any input.
Thank you,
Christine
chris85016 is offline   Reply With Quote
Old 01-26-2011, 11:01 AM   #2
If you can get metal lath, that is what I would use.
Redgard is not needed on the preslope.
1/2" is fine for the curb on the sides. 1" for the top.
Redgarding the studs? NO. That would be anticpating a leak. The niche needs to have cbu all around, taped and Redgarded.
1 gallon should do the job.
Here's some info: http://www.ontariotile.com/preslope.html
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
The Following User Says Thank You to Mop in Hand For This Useful Post:
chris85016 (05-11-2011)
Tags
curb, niche, pan, redguard, shower
