Shower Pan Install - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 03:09 PM   #1
shower pan install
I am installing a fiberglass corner shower pan. I know that I need to set the pan in some type of mortar bed and place plastic over said mortar. What type of mortar should I use if there is a proper type.
deal is offline   Reply With Quote
Old 05-03-2011, 10:20 AM   #2
Rewards Points: 5,336
You can use a sand or mortar mix.
Who told you about the plastic?
Ron
Old 05-09-2011, 10:18 AM   #3
Ron-
I have read on other websites that suggest the plastic. I'm assuming that its in case you ever have to take the pan back up.
Old 05-09-2011, 01:04 PM   #4
Rewards Points: 103
Per HD guy recommendation I used Stucco Mortar Mix to install a new acrylic Swanstone Shower pan just two weeks ago.
sukhenkoi is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Install DensGuard over DensArmour for shower? lk55 Kitchen & Bath Remodeling 1 01-13-2010 08:52 AM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 02:20 PM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 08:36 PM
