Shower Pan On Concrete Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 06:41 PM   #1
shower pan on concrete floor
my basement has a concrete shower, walls and floor. it is painted now and we would like to tile the floor and walls. the drain is located towards one of the walls, not centered. i need to raise the area on the far side from the drain and raise the actual area around the drain about 1/2 so someone won't slip into the drain area. not sure what to use of how to do it. this will be my first experience and just don't want to mess it up too badly. any ideas are appreciated
2033KP% is offline   Reply With Quote
Old 02-20-2011, 07:10 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Can you post some pics? That may get the ball rolling. It is sometimes hard to picture a situation with just a description.
Old 02-20-2011, 07:21 PM   #3
DIY staff
Rewards Points: 7,174
Where are you located? If you post a picture we can help--I suspect you may need a new drain set to make this happen.--Mike---
installing shower pan on a concrete floor sv9779 Remodeling 19 03-13-2011 11:03 AM
Help with shower drain install in concrete floor!! psychomti Plumbing 0 05-17-2010 02:54 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 09:23 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
