Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-08-2013, 09:18 AM   #1
Shower next to pocket door?
After brainstorming ideas for our master bathroom renovation my fiance and I where wondering if we could have a pocket door right next to where our shower is.
I have never done a pocket door myself so I'm wondering if there will be enough support from the pocket door framing to hold up the durock + tile.
With a pocket door i will be able to add more horizontal supports or will anything like that impede the pocket door?
I have attached a photo to give a better idea of what I'm talking about, the red area is the door when open and the orange area is the wall where the door would slide back into.
CMB00 is offline   Reply With Quote
Old 01-08-2013, 09:54 AM   #2
Every interior door in my log home is a pocket door (that's what the wife wanted). There are different styles of pocket door kits. Some have horizontal bracing; mine do not. I suspect they could not adequately support cement board, and even if they could, there would be too much flex for tiling.
I suggest you check around for the kits that are available and try to determine if there's one that would support the weight.
I got my door kits at Home Depot, and do not recommend them. The instructions read like they were translated into English from Swahili by a Chinaman. Installing them was one of those tasks that took an hour and a half the first time, and 20 minutes each thereafter.
The Following User Says Thank You to md2lgyk For This Useful Post:
CMB00 (01-08-2013)
Old 01-08-2013, 10:05 AM   #3
Not going to work.
Old 01-08-2013, 10:19 AM   #4
the Musigician
DangerMouse's Avatar
Johnsonhardware PD kits have STEEL WRAPPED wood vertical studs/supports. Are you guys trying to tell us that would not hold cement board?
CMBOO: I think you'd have little to zero problems doing what you want if done correctly, using quality products.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
CMB00 (01-08-2013)
Old 01-08-2013, 10:22 AM   #5
DM
That's what i have been reading. To use a quality kit and not something from HD and i will be fine.
Thanks for your reply!
Old 01-08-2013, 10:26 AM   #6
the Musigician
Originally Posted by CMB00 View Post
i will be fine.
Absolutely. Johnsonhardware.com is the ONLY pocket door hardware I have ever used. I've seen the "MIC" garbage and there is a WORLD of difference in the quality. As long as you don't have any restrictions on the thickness of the wall, you'll have zero problems. Tile and everything. If you need any help, come back here and ask the tile guys. Bud and Jaz are great...as well as others
DM
Old 01-08-2013, 10:57 AM   #7
Stuck in the 70's
Blondesense's Avatar
If this is just a shower (and not a tub/shower) could you add more framing and lose a couple of inches from the shower?
The Following User Says Thank You to Blondesense For This Useful Post:
drtbk4ever (01-08-2013)
Old 01-08-2013, 04:02 PM   #8
I have a pocket door that stores behind a full size shower,had it put in when we built our house,no special kits or hardware was used.
Canarywood1 is offline   Reply With Quote
Old 01-08-2013, 04:54 PM   #9
remodeling pro
The only thing I would do is to use thicker studs inside the shower interior than the ones that come with the door kit. I would be leary to hang cement board and tile on the flimsy supplied studs. As already posted......use Johnson kit. I have used metal stud track (strutural gauge, not drywall) and a couple layers of ripped birch plywood to manufacture heavy duty versions of the manufacturer's studs.
troubleseeker is offline   Reply With Quote
Old 01-08-2013, 04:54 PM   #10
Super Moderator
I usually fill in the open spaces between the nailers with 3/4" plywood---stiffens up the wall a lot--
still--a second layer of 3/4" would make the wall system safer for tile----
Old 01-08-2013, 05:13 PM   #11
Interesting. The kits I used also have steel-wrapped vertical studs, but there is still a lot of flex.
Old 01-08-2013, 07:55 PM   #12
Because it's in the bathroom, make sure the track and hardware are rust resistant. Another choice for pocket door hardware is Grant. You can opt for aluminum I beam track.
carpdad is offline   Reply With Quote
Old 01-08-2013, 07:58 PM   #13
bbo
I'd leave the shower wall alone and move the door a few inches to the right in the closet.
bbo is offline   Reply With Quote
bypass shower door height (Need more height!) KAdams4458 Kitchen & Bath Remodeling 14 10-30-2011 11:04 PM
Pocket door off track droopdog7 Building & Construction 1 03-14-2011 05:02 PM
pocket door help samuel11 Building & Construction 7 08-19-2010 03:44 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
