-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Shower next to pocket door? (http://www.diychatroom.com/f80/shower-next-pocket-door-168557/)
CMB00 01-08-2013 09:18 AM
1 Attachment(s)
After brainstorming ideas for our master bathroom renovation my fiance and I where wondering if we could have a pocket door right next to where our shower is.
I have never done a pocket door myself so I'm wondering if there will be enough support from the pocket door framing to hold up the durock + tile.
With a pocket door i will be able to add more horizontal supports or will anything like that impede the pocket door?
I have attached a photo to give a better idea of what I'm talking about, the red area is the door when open and the orange area is the wall where the door would slide back into.
md2lgyk 01-08-2013 09:54 AM
Every interior door in my log home is a pocket door (that's what the wife wanted). There are different styles of pocket door kits. Some have horizontal bracing; mine do not. I suspect they could not adequately support cement board, and even if they could, there would be too much flex for tiling.
I suggest you check around for the kits that are available and try to determine if there's one that would support the weight.
I got my door kits at Home Depot, and do not recommend them. The instructions read like they were translated into English from Swahili by a Chinaman. Installing them was one of those tasks that took an hour and a half the first time, and 20 minutes each thereafter.
joecaption 01-08-2013 10:05 AM
Not going to work.
DangerMouse 01-08-2013 10:19 AM
Johnsonhardware PD kits have STEEL WRAPPED wood vertical studs/supports. Are you guys trying to tell us that would not hold cement board?
CMBOO: I think you'd have little to zero problems doing what you want if done correctly, using quality products. :)
DM
CMB00 01-08-2013 10:22 AM
DM
That's what i have been reading. To use a quality kit and not something from HD and i will be fine.
Thanks for your reply!
DangerMouse 01-08-2013 10:26 AM
Originally Posted by CMB00 (Post 1088929)
i will be fine.
Absolutely. Johnsonhardware.com is the ONLY pocket door hardware I have ever used. I've seen the "MIC" garbage and there is a WORLD of difference in the quality. As long as you don't have any restrictions on the thickness of the wall, you'll have zero problems. Tile and everything. If you need any help, come back here and ask the tile guys. Bud and Jaz are great...as well as others :)
DM
Blondesense 01-08-2013 10:57 AM
If this is just a shower (and not a tub/shower) could you add more framing and lose a couple of inches from the shower?
Canarywood1 01-08-2013 04:02 PM
I have a pocket door that stores behind a full size shower,had it put in when we built our house,no special kits or hardware was used.
troubleseeker 01-08-2013 04:54 PM
The only thing I would do is to use thicker studs inside the shower interior than the ones that come with the door kit. I would be leary to hang cement board and tile on the flimsy supplied studs. As already posted......use Johnson kit. I have used metal stud track (strutural gauge, not drywall) and a couple layers of ripped birch plywood to manufacture heavy duty versions of the manufacturer's studs.
oh'mike 01-08-2013 04:54 PM
I usually fill in the open spaces between the nailers with 3/4" plywood---stiffens up the wall a lot--
still--a second layer of 3/4" would make the wall system safer for tile----
md2lgyk 01-08-2013 05:13 PM
Interesting. The kits I used also have steel-wrapped vertical studs, but there is still a lot of flex.
carpdad 01-08-2013 07:55 PM
Because it's in the bathroom, make sure the track and hardware are rust resistant. Another choice for pocket door hardware is Grant. You can opt for aluminum I beam track.
bbo 01-08-2013 07:58 PM
I'd leave the shower wall alone and move the door a few inches to the right in the closet.
