Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 08-14-2012, 09:54 PM   #16
Shower floor repair
Removed all the onyx board and greenboard. Down to studs now. Glad I took the onyx bd off. After I got the first panel off, the rest came easy. Not really secured to the greenboard very well. Would not have held the tile.
pinkertonpv is offline   Reply With Quote
Old 08-14-2012, 10:37 PM   #17
Shower floor repair
Thanks Oh Mike; Your url gives clear instruction on how to do it.
I tore out the onyx bd and green bd. Down to the studs now. will finish the subfloor and drain tomorrow and start the pre-pan. Will post tomorrow night on progress.
Old 08-16-2012, 08:18 AM   #18
Shower floor repair
Didn't get as much done yesterday. put in a few more supports for subfloor. cut hole for drain. Added another sheet of plywood to floor to strengthen it.
Will finish installing drain, and pre-pan today. Will try to post pictures tonight.
Old 08-23-2012, 10:03 PM   #19
Smile
Shower floor repair
Originally Posted by pinkertonpv View Post
The Master bath shower in a 20 yr old house I recently purchased had a major water leak. The shower is 4 ft by 8 ft and is lined with what appears to be cultured marble including the floor.
The floor had several cracks that had been caulked to stop the leak. After checking the floor from the crawl space and seeing the rotted wood, I removed the floor with hammer and chisel/crowbar. Underneath the floor was about 2 1/2 inch thick circles of what appeared to be Quickrete.
After removing this I was down to the rotted sub-floor. There was no pan liner, membrane or any thing else between the concrete and sub-floor. I removed the rotted portion.
Along the walls at the original floor level are one inch thick trim pieces of the cultured marble that I left in place. So the sub-floor is 2 3/4 in below the trim. There is considerable rotted wood under the wall with the shower door; however, all other walls and wood appear to be solid. I will replace all rotted wood from the crawl space beneath the floor.
My question is how to replace the floor. Videos on the web show in new construction installing sub-floor, tar-paper, pre-pan mix w/slope to drain, liner and pan w/slope to drain and finally tile.
Cement board is used on the walls. I don't want to remove the cultured marble on the walls but will probably have to remove the bottom 6 inches of the wall along with the trim. Will probably have to remove the C/M at the door to insure pan and liner are correctly installed.
Should I replace the bottom 6 inches with cement board over the membrane liner? Then same tile on floor goes up backer board? Can I tile over the cultured marble?
Do I need to attach cement board or some other backer board over the C/M first before the tile? Or do I need to remove the C/M if I want to add tile on walls? This may be necessary for the shower door wall if the rotted wood goes up the studs. Haven't seen that yet.
Any comments are welcome.
Hey,
When you do repair or replace the subfloor, we have a great little tool that is cheap, simple to use, and works great to slope your shower floor - EZ Slope float strips. It works for any size or shape shower floor, and it doesn't matter where the drain is located in the floor! Check it out at www.ezslope.net
It's the hard part of doing a tile shower, but this makes it simple for anyone to do!
Joe
ezslope is offline   Reply With Quote
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General Discussion 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
