Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 08-14-2012, 10:08 AM   #1
Shower floor
Hello, I have a tiled shower floor that was improperly placed. Liner was put down, and thin set was used to level off entire shower floor. It was floated improperly, and then the tiles were laid. I chipped up all the tile, and now I have the thin set left. Can I take out all the high spots of thinset, then float hydraulic cement. Or do I have to take everything out to the subfloor.
kevmnrr is offline   Reply With Quote
Old 08-14-2012, 11:28 PM   #2
Shower floor
Do you know what a shower pan and the pre-slope are? You can check into it, but what you want to do is have about an 8' step up from the floor into your shower. On the inside of this, you will pour a pre-slope. This is a concrete type material minimum 1 1/4" thick. On top of this goes your waterproof membrane, the another layer of the the concrete type material. On top of this goes your tile.
If you don't have something like this, then you need to start over.
cleveman is offline   Reply With Quote
Old 08-15-2012, 06:19 AM   #3
Shower floor
Great, I'll look into it. thanks
Old 08-15-2012, 01:05 PM   #4
Stuck in the 70's
Blondesense's Avatar
Shower floor
If you know it was done wrong, pull it out and do it right.
http://www.ontariotile.com/preslope.html
Shower floor repair pinkertonpv Kitchen & Bath Remodeling 18 08-23-2012 10:03 PM
Travertine Shower Floor smstone Flooring 2 06-21-2011 07:25 PM
Shower Floor Bobo Jenkins Flooring 0 05-24-2011 09:10 PM
Lowering Shower floor Steve Burke Kitchen & Bath Remodeling 3 02-16-2010 12:21 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
