Shower Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 11:50 AM   #1
Send a message via Yahoo to diyourself1
shower floor
when installing a drain in new shower floor using backer boards do you set the first part of drain in hardi board or directly to wood subfloor? i have the three part drain.
diyourself1 is offline   Reply With Quote
Old 08-05-2011, 12:43 PM   #2
Experienced
Jackofall1's Avatar
Welcome diyourself1, to the best dary DIY'r site on the web.
You may want to rethink, research the materials used for the floor/base of you shower project. Hardi-board is not really recommended as far as I know for use as shower pan material.
Second question is ...... have you installed a proper liner?
Mark
Old 08-05-2011, 10:47 PM   #3
you are clearly very lost, but thats ok, u came to the right place. Its a good idea to fully understand the procedure before you start, rather than finding out later you have to redo it all.
please read this:
http://www.ontariotile.com/preslope.html
or this:
http://www.ontariotile.com/kerdi-showerpan.html
if you're going to do a custom tiled shower pan, those are the two ways you should consider. Forget about the preformed ready-to-tile shower bases.
acerunner is offline   Reply With Quote
Old 08-05-2011, 11:54 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now you know you are headed in the wrong direction. DON'T do what you are thinking, it won't work.
acerunner left out the simplest shower floor system of them all. Take a look at the "Schluter System's Shower Kits."
We are here to help you through any of them you choose.
XXX
Travertine Shower Floor smstone Flooring 2 06-21-2011 07:25 PM
Shower Floor Bobo Jenkins Flooring 0 05-24-2011 09:10 PM
Lowering Shower floor Steve Burke Kitchen & Bath Remodeling 3 02-16-2010 12:21 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 09:49 PM
