Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 03-26-2012, 04:58 PM   #1
shower drain screw broke off
how to take broken screw out of shower drain cover
brian allendale is offline   Reply With Quote
Old 03-27-2012, 07:26 AM   #2
depends on the material of the screw and what it is screwed into. My first thought is, is there any thing left that you can get pliers on?? Usually not. Next thought would be an 'easy out' screw extractor. It requires drilling a hole in the screw just smaller than the extractor. Last, drill out the screw being careful not to damage the threads in the part, then rethread with a tap.
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 07:28 AM
Shower Drain Clogged? decaboy Plumbing 2 04-16-2011 11:00 AM
Centering existing drain to shower insert? Squeakyhinge Plumbing 5 04-07-2011 08:27 AM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 10 01-25-2010 11:01 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
