Shower Drain Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 01:11 PM   #1
GeorgeDupreeJr
shower Drain pan
I have a concret floor home my bathroom has an old tub but i want to convert it to a walk in shower how do i go about moving the drain to the center or can i leave it at the end of the shower an if i can how do i go about doing the slope from one end to the other?
george115855 is offline   Reply With Quote
Old 05-30-2011, 08:31 AM   #2
Rewards Points: 5,336
You can do either scenario. If you're doing your own pan, they sell plastic sloped runners you can set up to the drain. You build a perimeter frame to the drain. Fill the sections with drypack mud to the tops of the framework. You then remove the individual pieces and fill in the spaces with the mud.
You'll have to extend the drain upward to the proper level and be able to install the liner so the base is waterproof.
To move the drain, jackhammer the slab and move the drain where you want. Just make sure you maintain a slope to the stack so the water drains properly.
Ron
Old 05-30-2011, 08:42 AM   #3
DIY staff
Rewards Points: 7,174
You need a 2" drain for a shower--If you are converting from a tub (1 1/2" drain) you will need to change that.
Ceramic tile installation. Shower construction, installing floor and wall tile.
This links covers the basics of a lined pan system.
Old 06-07-2011, 08:40 AM   #4
Shower Drain Pan
You can leave the drain where it is. Just make sure that you pick the point farthest away from the drain as your start point for your slope, highest point. Make a level line around the shower from that point and slope everything to the drain so your tile has a level starting line when the shower pan is complete. This link shows how to build a mortar shower pan.
http://icreatables.com/floorings/shower-pan-mortar.html
Christopher
icreate is offline   Reply With Quote
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-22-2010 12:45 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Big Mistake with a basement shower drain lindq175 Plumbing 4 10-06-2009 03:11 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
