Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-13-2011, 10:27 AM   #1
shower drain extension
I am tiling over old tile in my shower. I want to raise the drain but from what I read extender kits require screw holes in the old drain flange to attach to. My old flange held the drain grill with springy arms (tabs) No screw holes. Is there an extender kit for me or what do I have to do to extend my drain.
Annibye is offline   Reply With Quote
Old 02-13-2011, 12:02 PM   #2
Tileguy
Bud Cline's Avatar
That problem comes up frequently and it isn't likely there is an extender for that particular drain assembly.
I would remove the old tile to about 10-12 inches back from the drain. Then use filler to re-slope that area from the top surface of the old tile to the low-point next to the drain assembly. This will result in a short resloping of the floor in that area but will allow the new tile to flush up with the top of the old drain as it should be.
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-22-2010 12:45 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Big Mistake with a basement shower drain lindq175 Plumbing 4 10-06-2009 03:11 PM
