Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-22-2010, 09:35 AM   #1
Joe F's Avatar
Shower door size
I'm probably making more of this than I need to, but...
I have a stand up shower with a 44" opening. I'm planning to install bypass doors. My shower door size choices are 40-44 or 44-48. Which one should go with? Price is the same. My concern is that the smaller one might be more prone to having some leakage at the overlap. Conversely, the larger one will have a smaller entry/exit opening area.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 11-23-2010, 10:25 AM   #2
Stuck in the 70's
Blondesense's Avatar
Shower door size
FWIW, sometimes in a real tight shower the way you close the doors can make a difference.
If your shower head is on the side rather than opposite the doors, by showering with the inside door closer to the shower head you will minimize any chance of leakage.
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General Discussion 0 11-12-2009 01:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
