Shower Ceiling Tiling - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 07:10 PM   #1
Rewards Points: 396
Shower ceiling tiling
Do you think its ok to tile the shower walls and leave the ceiling with drywall? If I decide to tile the ceiling I would use kerdi along with the rest of the shower. Above the shower is the attic which has faced insulation. Can I install kerdi on the ceiling or would that be considered a double vapor barrier?
detroittigerfan is offline   Reply With Quote
Old 11-20-2013, 06:02 AM   #2
Rewards Points: 14,312
BY far more common to not have tile on the ceiling and just sheetrock.
Old 11-20-2013, 09:50 AM   #3
Rewards Points: 396
Im just worried about water and moisture causing damage to the drywall. Should I use green board and a moisture resistant primer and paint?
Old 11-24-2013, 10:53 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
No, you should not use green board on that ceiling, unless...... Green board requires ceiling joists that are 12" o.c. I bet you don't have that and I'll bet most drywall people and builders don't know that.
Regular wall board will work fine. I think the best type of paint to use on the walls and ceiling in a bathroom is Zinsser's Perma White.
Tiling the ceiling is a good thing, but not absolutely necessary.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
drtbk4ever (12-02-2013)
Old 11-25-2013, 10:11 AM   #5
Rewards Points: 396
Jaz
And why would you not want to use green board on the ceiling?
Old 11-25-2013, 05:29 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 422
I just wrote why, read again. (Hint; 12" o.c.)
Jaz
tiling a built-in shower seat diy'er on LI Tiling, ceramics, marble 14 02-25-2012 08:14 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 01:41 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
tiling shower ceiling rugbydew Remodeling 2 05-31-2009 06:15 PM
