Shower Bench? Need To Be Angled? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 12:45 PM   #1
Shower bench? Need to be angled?
We're installing a bench between the wall and our tub... The bench, and the walls surrounding the tub are going to be tiled... Does the bench need to have a slight angle for the water to drain?
travsav is offline   Reply With Quote
Old 02-18-2011, 02:12 PM   #2
You talking to me?
nap's Avatar
Rewards Points: 6,290
Need? well, you can do whatever you want but failing to provide for it to drain will result in a pool of water that is unwelcome for a variety of reasons.
so, yes, the bench should be inclined enough to prevent standing water on the bench. If the surface is really flat, it doesn't take much but when installing tile, you often end up with an not quite perfectly flat surface so you can end up with a sunken spot. Just make sure when all is said and done, there is no pooling.
tile shower bench bluebird5 Flooring 6 02-13-2011 09:35 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Suggested Shower Bench Dimensions spQQk Plumbing 1 03-06-2009 02:19 PM
Retiling Shower Bench - HELP Jamboy Remodeling 4 10-09-2007 10:03 AM
Retiling Shower Bench - HELP Jamboy Building & Construction 2 10-07-2007 11:56 AM
