Shimming Vanity Legs - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 06:15 PM   #1
shimming vanity legs
My walls in the bathroom are not straight. I have a new vanity that is a tradional style with short Queen Anne style legs. If you put the vanity right up next to the wall then the front legs are off the floor by quite a bit and the vanity does not look level. If I put the vanity on its 4 legs then I have about an inch or two between back of vanity and the wall and it does look level. I need some help. Thanks for any advice you can give me. Karen
ksspears is offline   Reply With Quote
Old 12-11-2010, 07:07 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
so, is it the floor or the wall.
You would want to set the top level, or quite close. If you don't have a level, this would be a good reason to buy or borrow one.
Old 12-11-2010, 08:42 PM   #3
It is the plaster wall. My house is about 120 years old.
Old 12-11-2010, 09:32 PM   #4
nap
You talking to me?
nap's Avatar
ouch.
hang on for some of the carpenter/cabinet guys that float around occasionally. Given the legs on the unit, I'm kind of at a loss as to how to set it level and not have the big gap behind it. Simple trimming/shimming the legs won't allow you to set it level and meet the wall.
Does this have a back splash? attached or separate? Is the top already attached or do you need to set it? Do you think you can move the top back far enough to cover the gap and still leave a hangover edge in front?
I think you are going to get a fairly accurate measurement for the gap behind the unit when it is level.
Old 12-11-2010, 10:22 PM   #5
I bought this vanity preassembled and had it shipped from Florida. The granite top does not come off. It has a 1" backsplash.
Old 12-11-2010, 10:46 PM   #6
nap
You talking to me?
nap's Avatar
it's getting worse as we go.
I'm at a loss. Hopefully somebody else will have some bright ideas.
Old 12-11-2010, 10:54 PM   #7
Thanks for trying. I noticed on one post that they bought a shelf to put over the backsplash to try and hide it. Might be a little much since my backsplash is only 1" high but I can try it.
Old 12-11-2010, 10:58 PM   #8
nap
You talking to me?
nap's Avatar
not a bad idea but you would still have the gap visible from the sides. I know what I would do but then, that's me. I would fix the wall
Old 12-11-2010, 11:10 PM   #9
Now that is when I say 'Ouch" A lot of money for a cashier at a major retail store. I can't even get my bathroom vented because of my plaster ceiling. Can't get it vented through the outside wall because of the slant of the roof. No room in the attic to reach it. But what can I say, I love this old house.
Old 12-12-2010, 07:46 AM   #10
kwikfishron's Avatar
Rewards Points: 996
If your satisfied with how it sits on the legs other than the gap you could build out some trim to create a shelf, like a small fireplace mantel.
kwikfishron is online now   Reply With Quote
Old 12-12-2010, 10:25 AM   #11
Thank you, that is one idea I never thought of and its something I can do myself. I bought the little Craftsman auto hammer and now I can try it out. The only problem is, it has curvy sides. I added an attachment so you can see what I am talking about.
Old 12-12-2010, 12:41 PM   #12
Rewards Points: 996
Maybe trim the wall out and hang a mirror on that so it sits on the vanity.
Old 12-12-2010, 12:46 PM   #13
Thanks for your suggestions. I will have to think over both choices.
How can I install this vanity without removing the top? Haleon General DIY Discussions 13 09-25-2010 01:13 PM
Vanity - too tight a fit? 9728 Building & Construction 7 12-14-2009 08:42 AM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
