Shimming Durock - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 06:30 PM   #1
Rewards Points: 150
Shimming Durock
I have a kohler 9026 shower receptor installed in a gutted alcove on a concrete floor. Kohler requires that the concrete board be shimmed out as in attached image. I've gotten different stories from Kohler and Durock on how best to accomplish this.
Kohler says use metal shims (huh?). Durock says just fir out the studs (I guess about 1/4").
What about using 2 layers board (one 1/4" layer and one 1/2")? Are there any caveats to this? If not, should both layers be Durock or would something like hardie board be better for the under layer?
Thanks!
rightit is offline   Reply With Quote
Old 06-17-2012, 06:48 PM   #2
DIY staff
Rewards Points: 7,174
I would use wood rippers cut on my table saw---or store bought 1/4" furring strips--
Then water proof the face of the Durrock with a paint on membrane like Red Guard by custom or Hydroban by Latacrete--
No need for the expense and time involved with a double layer of concrete board---
rightit (06-17-2012)
Old 06-17-2012, 06:53 PM   #3
Rewards Points: 150
Good tip on the store bought strips. As for the Red Guard, it's already part of the plan. .
Thanks for the comments.
The Following User Says Thank You to rightit For This Useful Post:
oh'mike (06-17-2012)
Old 06-17-2012, 08:18 PM   #4
Rewards Points: 13,444
Lattis strips work fine. Lowes and HD both have them.
Old 06-17-2012, 10:41 PM   #5
Rewards Points: 150
Also, when installing in an alcove to receive tile, should back panel span stud to stud with side panels ending on the back panel?
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 07:48 PM
Gap between tub and durock (not lip) megablok Flooring 19 04-05-2012 10:15 AM
Liner and Durock placement rightit Kitchen & Bath Remodeling 7 03-13-2012 06:35 AM
Durock Question md2lgyk Concrete, Stone & Masonry 7 02-18-2012 07:25 AM
Bathroom - Durock murphy54 General DIY Discussions 12 02-10-2008 09:12 PM
