Sheetrocking Vertical - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 05:01 PM   #1
sheetrocking vertical
I am sheetrocking my bathroom ( besides the tub area which will be cement board) I can hang 2 sheets verticly and cover the whole wall. Is this ok or must I hang it horizontal
john123123 is offline   Reply With Quote
Old 03-27-2013, 05:19 PM   #2
Rewards Points: 13,228
No idea what's best unless we had a picture of what your doing.
If you can do it vertical in two sheets then two sheets horizontal will do the samething but you will not have to be going up and down the ladder to finish the seam.
Both ways will work just one is more work.
Old 03-27-2013, 06:10 PM   #3
dannyoung85's Avatar
Sheetrock is hung vertically in commercial applications all the time. I hung all the sheetrock in my basement vertically with no problems.
dannyoung85 is offline   Reply With Quote
Old 03-27-2013, 08:25 PM   #4
Rewards Points: 512
theres always big wars in the drywall section about hanging drywall vertical or horizontal. i believe there is no right or wrong way but whatever way works out the best then do that. so if vertical works out best then vertical is the way to go.
princelake is offline   Reply With Quote
Vertical Plywood Installation Roofmaster417 Roofing/Siding 14 01-24-2013 12:18 AM
How to handle the vertical spacing between HardiePanel vertical siding? rdaisley Building & Construction 3 10-28-2012 05:56 PM
Connect vertical 4x6 posts to chimney lakemans Building & Construction 6 06-05-2012 07:29 AM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 02:51 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
