#1 |
securing a sliding shower door
hello all, not sure if i have the right forum for this, but i'm looking to install a sliding shower door and i'm concerned about securing it to the walls. the studs are off-center from the edge of the bath/shower so i can't screw it directly into the studs. i've thought about using some heavy duty wall anchors, but i'm hesitant. any thoughts?
#2 |
is there tile/ if no tile you may get away with using wall anchors and bedding the track in a high grade adhesive. others here will know types for high moisture areas
The older I get the better I was |
| Display Modes | |
| Plans or technique for a simple sliding door? | eastie | Carpentry | 3 | 05-03-2010 04:00 PM |
| Rehanging an exterior basement door | tputkey | Building & Construction | 9 | 05-21-2009 04:19 PM |
| Fitting Door Closers | clayton1302 | Carpentry | 6 | 05-09-2009 09:09 AM |
| installing patio sliding door on concrete pad | jwms | Building & Construction | 6 | 04-19-2009 01:46 PM |
