#1 |
Screws for cabinet install
What are the best screws to use to install 1/2" plywood backed cabinets? Also, what screws are best for connecting the face frames?
Thanks, Eric |
#2 |
Ebie,
Screws for fastening cabinets to the walls: http://www.woodcraft.com/PRODUCT/202...FQuynQod13gAJA For fastening faceframe to faceframe: http://www.woodcraft.com/product/202...-500piece.aspx Faceframes should still be predrilled even though the screws are self drillers. Drill the skinnier hole through the first faceframe and into the second. Drill a bigger hole just through the first faceframe so screw slides through it and bites into the second. I also use a countersink bit to make a slight bevel so the screw head ends up just below flush with the faceframe edge. I also drill a pilot hole just a tag larger than the screws used to fasten the cabinets to the wall. Mike Hawkins
| The Following User Says Thank You to firehawkmph For This Useful Post: | Ebierley (02-08-2013) |
| Display Modes | |
| Can I use deck screws with Hardibacker? | spaceman spif | Kitchen & Bath Remodeling | 10 | 10-26-2010 03:11 PM |
| Need Nickle screws for front door hinge | orca | Building & Construction | 4 | 06-05-2010 11:07 PM |
| Stainless steel deck screws and hardibacker | johnknez | Building & Construction | 1 | 10-09-2009 09:56 AM |
| How to install resilient channel on ceiling | Bcoleman6 | Building & Construction | 1 | 08-22-2008 03:29 PM |
| Call for help with fiberglass tub install | yohan | Plumbing | 3 | 05-24-2008 05:23 PM |
