Safety Of Big Piece Granite Slab Around Bathtub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 11:28 AM   #1
safety of big piece granite slab around bathtub
I am very interested in installing three big pieces granite slabs around bath tub. However these big pieces are very heavy, so I worry about the safety issue. Could they collapse and kill my kid?
I know I am a little bit paranoid.
pttcc is offline   Reply With Quote
Old 11-29-2010, 01:56 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and what will support these granite slabs?
XXX
Old 11-29-2010, 02:00 PM   #3
I will put water barrier and 1/2" cement board on studs. Then slab on top of cement board. Is thin set strong enough to provide enough strength?
Old 11-29-2010, 09:37 PM   #4
Rewards Points: 276
I've seen this done with a solid surface material in a hotel, something like Corian. I believe it was screwed on with the screws sealed.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
pttcc (11-30-2010)
Can I undercut/grind granite? joemontana16 Flooring 3 01-20-2010 10:26 AM
three piece bathtub replacement units eric haley Plumbing 1 03-17-2009 05:27 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Framing for bathtub safety bar Randell Tarin Building & Construction 4 01-27-2008 08:06 AM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
