At The Risk Of Being Flamed...tub Leveling Alternative. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 09:20 AM   #1
Rewards Points: 117
At the risk of being flamed...tub leveling alternative.
I'm going to be starting my bathroom remodel here shortly, and while I haven't purchased the tub/surround, I know what make/model I'm using here.
Reading the installation instructions, they are a manufacturer who actually does recommend setting the tub in a bed of mortar mixture for leveling. I have no problem this this, other than mess and the tight space I'm going to be working with, so here's my question.
While it's not mentioned in the manufacturers recommendations, can non-expandable spray foam be used as a leveler? I couldn't find much on the topic other than the recommendation of NOT to use the expanding foam for obvious reasons. My main concern, aside from it not being listed in the manufacturer's recommendation, is the fact that I don't believe foam is a load bearing/support product, correct?
Secondly, the manufacturer mentions using a felt pad if provided in place of the mortar bed. What is this? I've never heard use of a felt pad for a leveler.
Again, feel free to slap some sense into me here if necessary.
mgh-pa is offline   Reply With Quote
Old 01-05-2013, 10:25 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
Good question.....I don't know if I have the answer....but.....I used the foam on our fiberglass tub when I installed it.
Since the tub is above floor level, I made a platform that followed the slope of the tub. There is about 1" between it and the tub. I then used the spray foam......expanding spray foam. The next morning the tub was sitting about 2" above the frame.....ooopppsss...
So...I cut out the foam (pretty quick just using a hand saw)...cleaned everthing up...tried it again...used less foam and this time I filled the tub about half way with water. I came out right this time.
Now....with that said....is that the best way? I don't know. I'm interested to hear input from the experts. Joecaption? OhMike? Jaz? I'll be doing my wife's new bathtub in about a month or so....
But I will point out that it's been about 8 years now since we did it....I don't see any flex in the bottom....nice thing about the foam...it's 'warm'...and quiet.....as when the kids drop toys in the tub.....
ddawg16 is online now   Reply With Quote
Old 01-05-2013, 10:35 AM   #3
Rewards Points: 13,300
I would not do it, for one if it ws such a good idea why would the manufacture not suggest it, as you mentioned it's compressable so a void may form, taking the risk of it lifting as it cures, expecive if you bought enough cans to completly fill the area. I'm sure there's more.
I try to buy a better quality tub or shower that's sellf supporting or come with a foam block that the whole thing sits on that's preformed.
Duckweather (01-05-2013)
Old 01-05-2013, 12:20 PM   #4
Rewards Points: 117
Any recommendations on a tub/shower that would meet those requirements?
Old 01-05-2013, 06:09 PM   #5
remodeling pro
Use the mortar, mixed to a consistency so that the weight of the tub can squeeze it flat as it settles in. You don't say what material the tub is, but this bed is to provide a solid, flex free support for the bottom of the tub, especially important for fiberglass , acrylic, or light weight steel tubs.
troubleseeker is offline   Reply With Quote
Old 01-05-2013, 07:16 PM   #6
Rewards Points: 530
Foam degrades as time passes.
carpdad is offline   Reply With Quote
Old 01-05-2013, 07:32 PM   #7
I knew a plumber that would use drywall compound under everything. I would just use the mortar mix and be done with it.
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
oh'mike (01-05-2013)
Old 01-05-2013, 10:20 PM   #8
DIY staff
Rewards Points: 7,174
Masons mix--right on the plywood floor---set the tub --wiggle it until into position secure the flange to the framing and leave it alone until set.
Do NOT step into the tub to set it--you might over do it--causing a hollow under the tub---
Gypcrete also works
Old 01-06-2013, 08:18 AM   #9
Rewards Points: 1,216
"Not if its kept from sunlight"
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-06-2013, 08:22 AM   #10
I used expanding foam under my shower about 10 years ago no problem.
Now if I was going to install a bathtub I would probably use non shrink grout, or foam. Non shrink grout is what it says, once it sets that's it no shrinkage.
Old 01-06-2013, 04:17 PM   #11
remodeling pro
I don't have much faith in the mud, but it is actually the recommended base in the instructions of a few acrylic tub manufacturers. Maybe there is a concern about the corrossiveness of cement based product? I still use the morter.
Old 01-06-2013, 04:29 PM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Gypcrete also works
What is Gypcrete? Which would be best, the Gypcrete or Mason's Mix?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-06-2013, 04:53 PM   #13
Rewards Points: 2,238
gyp-crete (flo-crete) -
something like "floor leveler".
I'd use mortar.
"RF"
rossfingal is offline   Reply With Quote
The Following 2 Users Say Thank You to rossfingal For This Useful Post:
BigJim (01-06-2013), oh'mike (01-06-2013)
Old 01-06-2013, 05:19 PM   #14
DIY staff
Ross is right----you would use Gypcrete only if you had a bag on the job for something else---
Otherwise masons mortar is the best choice
BigJim (01-06-2013)
Old 01-08-2013, 12:00 PM   #15
Rewards Points: 117
Thanks, guys. I appreciate it. I will go with the mortar mix. No reason to take unneeded risks.
Door issues leveling 1 degree slope in room Woodbury Carpentry 1 08-07-2012 07:24 AM
Looking for Dricore leveling alternative vluzhko Flooring 2 01-03-2012 06:10 PM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 07:50 PM
self leveling cement questions gramps416 Flooring 0 07-05-2010 10:36 PM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 04:58 PM
