Replacing Toilet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 10:47 AM   #1
replacing toilet
We have a toilet with 10" rough-in that needs replacing. All I see in the store is toilet with 12" rough-in. Do I have to find a 10" rough-in replacement?
gllasseigne is offline   Reply With Quote
Old 09-23-2012, 10:02 PM   #2
homeprova's Avatar
Home Depot, Lowes, plumbing supply house carries a 3" drain off set for this case that gives you an extra 1 1/2" which is all you need. You may have to remove the baseboard and/or shoe mold behind the base in order for it to fit. The part is around $10. You have to cut your plywood out that extra 2", cut the plumbing, and install the new drain. Do not over cut the plywood so that you cannot secure it.
homeprova is offline   Reply With Quote
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 11:43 PM
Toilet wont drain chazlew Plumbing 11 02-27-2011 11:08 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Replacing a toilet flange jayp Plumbing 5 06-11-2008 10:43 AM
