Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-22-2009, 05:06 PM   #1
Replacing tile surround with faux granite
I have received conflicting advice about remodeling my pink and green very 50s bathroom. I am thinking of removing the wall tiles and then using 3/8 cultured granite panels around the bathtub. Standard size; walls and ceiling quoted about $1500 for materials. However, a tile guy says I should replace the old tile with new tile, that I'd save a lot of $$. Another guys says that the wall tile is set in 4" mud and will be very difficult to get out. Any way to know who is right?
knharper is offline   Reply With Quote
Old 05-24-2009, 08:55 AM   #2
If the tile is over drywall, everything should be removed down to the studs. Then build back up using hardibacker or cement backer board. If it is a mud base(you can usually spot a mud base job easily, the tile sticks out about 1/2" instead of the usual 1/4"), you could chip off the old tile, but LOTS of work. And be careful not to crack the base. Removing a mud base is also difficult and messy.
Old 05-24-2009, 12:25 PM   #3
If it is on a mud base, can I just tile over the tile?
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 08:32 PM
Faux granite finish over existing tile countertop? Bulah Remodeling 1 02-15-2009 12:27 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 12:49 PM
