Replacing floor tile in shower
Jl,
I am with ARI I think too that it will leak.
I think the best thing to do is get that kerdi up the walls and lapped correctly. If you can't do this properly then I wouldn't do it at all because if it is done incorrectly it is merely placing a band aid on the wound and it may create a separate set of problems.
Like ARI said it is a pain and probably a lot of extra work but will be done right and then you can sleep at night not wondering. It may be something you can replace components but it may be something that is a tear out and replace.
Good luck and be safe!
James D. Van Raden Owner, Paragon Renovations Moorhead, MN/ Fargo, ND To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
"Committed to providing the finest renovation services available"
