Replacing Cooktop In Corian - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-01-2014, 10:52 AM   #1
Replacing cooktop in corian
I am replacing a gas cooktop in my corian countertop. The original hole is smaller than most available cooktops. I need to get about an extra half inch of clearance on each side to fit in the new cooktop. Any suggestions on the best sway to approach? I was thinking grinding but I don't currently own a handheld grinder, only a dremmel like tool. Thanks in advance for your advice.
Thecaptain15 is offline   Reply With Quote
Old 01-01-2014, 11:30 AM   #2
Rewards Points: 240
corian is plastic. get a jig saw and use it carefully. and it will go easily.
Fix'n it is offline   Reply With Quote
Old 01-01-2014, 11:48 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
Corian cuts easy with a carbide router bit. Clamp, carefully, a board as a guide to the top so the router will not get carried away and ruin your top. Don't clamp too tight or the top will break.
Be aware that Corian scratches fairly easy so protect the area you slide a tool across.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Thecaptain15 (01-04-2014)
Old 01-04-2014, 10:18 AM   #4
Big Jim,
Thanks for the advice. It worked perfectly, except for one of my kids ran up to me as I was finishing a pass, and I ended up going past where i needed to. There is now a small gap visible on one corner. Is there any substance I use to fill it in and hide it?
Old 01-04-2014, 10:51 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
Originally Posted by Thecaptain15 View Post
Big Jim,
You might contact a corian dealer and see if they have a colored filler for that, I know they use to have.
Jim
Old 01-04-2014, 02:07 PM   #6
Rewards Points: 3,130
Sounds like you blew a chance to buy an angle grinder. Inexpensive and amazingly useful tool once you have one.
New glass cooktop too small for hole in granite countertop smcc1123 Appliances 1 06-25-2012 09:47 AM
replacing range with cooktop and oven diy-diy Electrical 2 10-10-2011 07:18 PM
Cooktop cut-out accuracy... jdrunbike Appliances 5 04-13-2011 10:46 PM
Electric Cooktop too slow to heat coachgns Appliances 1 02-05-2011 03:45 PM
Replacing a cooktop JackCaster Electrical 3 07-23-2008 04:16 PM
