Replace Shower Stall With Tub On Cement Slab - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 12:12 PM   #1
Unhappy
Replace Shower Stall with Tub on Cement Slab
We have an old shower stall I want to tear out and replace with a tub and shower surround. Problem is we have a cement foundation and need advice on how to go about moving the drain. Since our finances are limited my husband and I will be doing this project ourselves along with some help from our friends. I've tried searching for diy videos but was only able to find the shower surround installation but nothing on the moving the drain. Also, any suggestions on what to look for when buying the surround? This wasn't my first choice, would rather do tile but it's the cheapest for our pocketbook.
Kat58 is offline   Reply With Quote
Old 03-10-2011, 12:56 PM   #2
DIY staff
Rewards Points: 7,174
Moving the drain usually requires renting a jack hammer for a few hours---
You won't need a neat hole--the tub will hide the patch.
How difficult the plumbing is depends on --what kind of pipe--and where the old line is going.
Old cast iron pipe might require renting a 'chain breaker' to crack the old iron drain--not a hard job,but one more trip to the store.
I suggest that you get the floor opened up and see what you are up against---then post a picture here. We will walk you through the job.
This job is well within the ability of anybody with common sense and some natural mechanical aptitude.
---Mike----
Old 03-10-2011, 06:40 PM   #3
Thanks! We won't be starting the project for another month or so, I'll post back then....thanks again!
Old 03-10-2011, 10:55 PM   #4
Rewards Points: 5,336
Just be sure there's no radiant heat in the slab. There are also issues with opening something called, "pre-tensioned" slabs.
Maybe the concrete guys will stop in.
Ron
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 02:31 PM
Handicapped shower stall reelwood Plumbing 5 10-28-2009 12:35 PM
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
Shower Stall shelf helpless handyman Building & Construction 3 08-28-2008 10:45 PM
Shower stall question... Alan Remodeling 1 05-31-2006 06:57 AM
