Repair Shower Stall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 04:08 PM   #1
Repair shower stall
1970's house built on slab (Florida), have found water damage under carpeting on adjacent room to master bath shower. Started removing old cracked grout and the wall tile that meets the floor tile had to be removed due to damage. Found at the bottom where wall meets floor what looks like mucky wet cement. Is this the pan deteriorating or from the back board? The back board looks like concrete and somewhat rusty looking. I have repaired a shower before above the tub in a newer home but this is new to me . Can I remove the wet stuff and let the shower dry out before repairing or do I have to repair the pan also?
Laurie Allen is offline   Reply With Quote
Old 02-23-2011, 04:40 PM   #2
Retired G.C.
Hey Laurie,
Sounds like the wet mucky stuff is deteriorating backer/wall board or mastic from the tile.
iIf you are getting water between the Base and the Wall. the whole install was probably not done correctly.
There should be a rubber/ PVC liner under the Base that extends up the wall about 6" above the Base to prevent water from getting out of the shower.
CharlieO is offline   Reply With Quote
The Following User Says Thank You to CharlieO For This Useful Post:
oh'mike (02-23-2011)
Old 02-24-2011, 08:50 AM   #3
Rewards Points: 5,336
If you post a picture it would help to see what you have.
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 08:54 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
shower stall with hole (cold air coming in) mcvane Plumbing 1 02-08-2009 10:41 PM
Stall Shower Renovation Rick Bruner General DIY Discussions 11 01-20-2008 06:34 PM
