Removing Window From Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 10:25 AM   #1
Removing window from shower
Is it wise to remove/eliminate a window from the shower?
kimm is offline   Reply With Quote
Old 06-09-2010, 10:32 AM   #2
Learning by Doing
Leah Frances's Avatar
This is an hard to answer question - I'll say it's never wise to change something that already exists. But, that's not really helpful, is it?
Maybe think about what you really want to know and ask that.....
Do YOU want to remove it? Do YOU want to keep it?
Do you want to know HOW to do it? Do you want to know the possible repercussions of removing it?
Is there a problem with the current window that needs to be fixed?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-09-2010, 08:37 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
A window in a shower is generally not a good idea. It is a weak point for water to penetrate and cause water damage, rot, and mold in the wall around and behind it.
However there are several variables to consider. A modern shower with a vinyl or glass block window high enough so the water does not hit it directly is okay.
What often happens in older homes is someone takes what was originally just a tub, and adds a shower above it, leaving an old wooden frame window in place. If this is the case and the shower hits it directly, then yes, it would be better off gone as it is unlikely to withstand water hitting it on a daily basis. At the very least it should be protected from direct spray.
Old 06-13-2010, 02:17 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Windows are never real practical in a shower as far as I'm concerned because of the challenges they can represent in waterproofing them. That's not to say it can't be done successfully.
Another question you must investigate is: What will happen to the appearance of the outside of the home and how can that be dealt with?
XXX
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
removing polyurethane from a window frame and molding diy'er on LI Painting 1 11-02-2009 09:54 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Shower Stall w/wall & window pccoach Remodeling 4 02-05-2007 07:25 AM
Shower window issue help! Ducowti Building & Construction 2 05-26-2005 03:36 AM
