Removing Silicone Caulking - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 11:24 PM   #1
removing silicone caulking
How can I remove silicone caulking from a new acrylic 3pc bathtub shower surround without damaging it or removing the bead.There is residue on the walls of the surround in areas from trying to smooth out the bead. Would like to remove the residue without damaging the surround.Help please.
Tooshadz is offline   Reply With Quote
Old 02-15-2010, 11:57 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
What a mess! Usually I use a razor blade, but obviously that isn't a good choice for your app. I'd try a mild remover such as goo-gone. It'll take some good fingernail action as well, but I think anything stronger such as mineral spirits would probably dull the finish.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-17-2010, 10:09 PM   #3
Barry
A plastic scraper is the only thing I can think of that might work. A razor blade will cut through most of the silicone, but will easily scratch the acrylic. There are no solvents that will dissolve it. This is why the instructions for silicone caulks say to mask the area first with masking tape on both sides - it's the only way to prevent residue on the surface. You've got a nearly impossible task on your hands.
Tub Refinisher is offline   Reply With Quote
Old 02-17-2010, 10:18 PM   #4
Learning by Doing
Leah Frances's Avatar
use the search forum on this site. Somewhere there is a great thread about this.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 11-24-2011, 10:40 AM   #5
Goof off in a spray can removed silicone caulking and paint from my plastic tub easily. You will want to wear a respirator as it is a potent solvent. Worked great.
Againdays is offline   Reply With Quote
Old 11-24-2011, 04:29 PM   #6
Too Short? Cut it Again!
Get your hands on some plastic razor blades. They are less likely to scratch than metal ones. They will fit in a standard holder. Your paint store may have them. I don't know about box stores. You can always order online. They are actually nice to have around for other projects like scraping paint from windows. They do not rust like metal ones.
The Following User Says Thank You to user1007 For This Useful Post:
carpdad (08-28-2014)
Old 08-26-2014, 10:09 PM   #7
Rewards Points: 4,792
Originally Posted by user1007 View Post
Get your hands on some plastic razor blades. They are actually nice to have around for other projects like scraping paint from windows.
Sounds like a nice alternative for some projects, but why would you want them for scraping paint from windows? Did you mean the glass or something else?
jeffnc is offline   Reply With Quote
Old 08-28-2014, 09:47 AM   #8
How are they on plastic or stone (counter tops)? Round off the edge?
I was afraid to use goo off in case it dulled the finish on plastics. I was able to clean off silicon residue with vinegar and kitchen sponge with green thing on one side? Stores also sell those pads that do not scratch.
carpdad is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
Removing Silicone Caulk... BillK40 Painting 39 10-28-2013 02:35 PM
removing silicone caulk from dryall, MDF 99BN99 Painting 2 07-12-2009 05:45 PM
silicone caulking over ceramic tile grout joints tonyg2 Flooring 5 11-16-2008 09:48 AM
caulking trim with silicone castleconcepts Painting 2 10-24-2005 12:16 AM
