Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 08-05-2005, 04:38 AM   #1
Removing painted wall paper
We want to repaint our living room but first of all, want to remove the existing wallpaper that has been painted over. Should we use a standard wallpaper remover or is there any tip we need to know?
carine is offline   Reply With Quote
Old 08-05-2005, 07:56 AM   #2
Hi
Here is a link to a thread with some tips already posted
I hope it helps you
http://discussdiy.com/showthread.php?s=&threadid=6
The fact it was painted over shouldn't change it too much. It will just make a bit tougher. but some wall papers have almost a painted somewhat sealed Finnish to begin with.
With the painted surface it may be even more important to score it. Their are hand tool that you run over the surface to perforate the outer layer to allow the moisture top get threw to loosen it up.
Link to example of as scorer tool
http://www.mainstsupply.com/product.cfm/5/68/56576
Mgmopar
MgMopar is offline   Reply With Quote
Old 08-05-2005, 08:53 AM   #3
thanks for the info and the links. we''ll see how it goes...
