Removing An Old Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-24-2009, 08:52 PM   #1
kvn
Removing an old shower pan
Hi, I'm remodeling an older basement bathroom and need to remove a shower pan so I can install a tile shower base.
I removed the shower surround and I need to remove the shower pan next. I tried using a pry bar and hammer, with no luck.
The shower pan doesn't appear to be nailed in, and is surrounded by a metal frame.
I attached a couple pictures of the shower pan... Any suggestions? Should I just get a power chipper/demolition hammer and break it up? Should I try to pry it out?
kvn is offline   Reply With Quote
Old 07-25-2009, 12:12 PM   #2
ccarlisle's Avatar
That looks solid all right...concrete with marble chips in it, I think. Rent an electric jackhammer.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 10-24-2010, 12:54 PM   #3
TGM
Talking
Removing an old concrete shower pan
Until yesterday, I had the same kind of shower pan. Using a fat black marker, I marked off 1-foot square cut lines. Directly crossing through the drain, I marked off additional 6-inch cut lines. Those last two served as stress relief to prevent the pipe below from cracking. I made my cuts with a masonry blade on a circular saw. I cut to a depth of 1 inch. Then I pounded an 11-inch spike with a 3-pound sledge hammer through the cut lines, starting with the outermost cut lines. The chunks of shower pan came out easily and nothing was damaged.
TGM is offline   Reply With Quote
Old 10-24-2010, 08:23 PM   #4
Rewards Points: 5,336
Ron
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 09:50 PM
Removing Shower jmnhdmil1 Plumbing 2 10-07-2007 06:07 AM
removing shower stall JohnH Plumbing 4 09-17-2007 03:40 PM
