Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-09-2013, 02:23 PM   #1
Removing decorated tile and replacing with plain tile.
My kitchen backsplash is white and has one row that has a fruit tile in every third spot. How do I remove the fruit tile and replace it with a black tile without messing up the backsplash.
anncollins is offline   Reply With Quote
Old 01-09-2013, 06:42 PM   #2
Got a picture?
Most often you remove the grout, and crack the tile in an X shape with a chisle, remove the tile and replace.
oh'mike (01-09-2013)
Old 01-09-2013, 06:47 PM   #3
Super Moderator
Joe 's method is the standard---those tile you described are soft ,white bisque---not much harder than plaster----
removing and replacing bathroom tile rainajz Kitchen & Bath Remodeling 1 02-11-2012 12:49 PM
Replacing Tile Floor in Shower banglenot Flooring 9 05-23-2011 10:05 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
Removing old 6" Tile and Replacing with 6" tile Mikey_B Tiling, ceramics, marble 1 07-09-2009 10:01 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
