#1 |
removing base cabinet
We are removing a 24 " base cabinet to install a dishwasher. We removed all the screws but the cabinet didn't budge. It is our suspicion that the counter top is glued to the cabinets. The top is laminate and has a corner seam that we know is glued. We really don't want to purchase new cabinets or counter tops..What do we need to do? We have a plumber to install dishwasher but need to get the cabinet out.
#2 |
gravity always wins
A couple of things to look at. Make sure the cabinet is not trapped behind the finished floor. Check to see if the counter top has a lip that hangs down over the face of the cabinet. If either of these conditions exist, then you may need to demolish the cabinet and take it out in pieces. If the counter is glued, take a shrp putty knife around the perimeter from the inside and cut the glue.
#3 |
Framing Contractor
If the top was built in place, it may have been nailed to the cabinet before the laminate was installed. Use a sawzall and cut the cabinet out in sections. the nails can then be cut off.
#4 |
Super Moderator
Have you looked for screws in the face frame?
The cabinet faces are usually screwed together to avoid gaps between the cabinets. Sometimes the screws are hidden under the hinges.
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| Wall oven too Wide for Cabinet | victor07 | Carpentry | 8 | 01-03-2011 12:09 AM |
| Double sink in a small base cabinet?? | J187 | Kitchen & Bath Remodeling | 2 | 12-06-2010 10:33 AM |
| Sink base vs regular base cabinets... | J187 | Kitchen & Bath Remodeling | 3 | 12-03-2010 08:40 AM |
| Need help! Cabinet install gone slightly wrong | eemichael83 | Carpentry | 14 | 10-26-2010 04:46 PM |
| Base cabinet install on uneven floor | no1hustler | General Discussion | 4 | 10-13-2010 03:52 PM |
