Removed Old Back Splash, Now Need Advice - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 08:24 AM   #1
removed old back splash, now need advice
I was wondering if there was any way beside scraping and sanding, to get a smooth enough surface to apply new ss tile back splash. After removing a painted brick facade the grout or mortar,glue are lseft which is a bumpy uneven surface. Was just wondering if ther are any suggestions before I make a huge dusty mess trying to scrape or sand it. It was applied directly to the original plaster and a few spots are nicked. would greatly appreciate any help. Thanks!
ddono is offline   Reply With Quote
Old 03-29-2011, 11:29 AM   #2
Rewards Points: 5,336
Use a pull scraper and get the high spots off. This causes little dust.
How smooth do you need it?
How are the SS tiles installed? Are they put on with a mastic?
If you need in very smooth, skim coat some compound on the wall.
Ron
Old 03-29-2011, 01:07 PM   #3
ss back splash
Thanks, Ron. It says to apply the tile with polyurethane premium construction adhesive.
Need Advice About Walling for Bath Remodel bremdogg55 Drywall & Plaster 7 12-05-2012 01:07 PM
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Back Splash Tile Help TTran Building & Construction 15 01-12-2009 04:03 PM
Tile Back splash over stove - Waste of time? Mr Chips Flooring 5 07-06-2008 02:46 PM
Installing A Back Splash bobo Carpentry 3 09-09-2006 03:36 PM
