Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-15-2004, 11:19 AM   #1
Remove mould from white sealant?
I've got mould/green stuff growing on the white sealant which provides a seal between the edge of the bath and the tiles. I've tried using the standard bathroom cleaner and leaving it to soak in, but it doesn't work. Will I have to remove the sealant and re-seal it?
kyodoc is offline   Reply With Quote
Old 07-09-2004, 12:38 AM   #2
Aussie Battler
Once this stuff is green she's hard to get back to white. Scrape it out and make sure you use a mold resistant silicon (Bath & Kitchen) most people fail to do this the first time round
imported_Alan is offline   Reply With Quote
Old 07-31-2004, 05:01 PM   #3
Lightbulb
I have found if the surfaces can handle it. Almost all bathroom tiles can. You can use straight chlorine bleach in a sprayer with caution. (bleach can be very harsh read labeling on bottle) and spray on the mold or mildew. Let this set for about two or three minutes and then thoroughly rinse. If it is indeed mold it should kill it and loosen it so regular cleaning methods should remove it. (Scotch bright, or green back of kitchen sponges work well but make sure it doesn't damage you finish).
MgMopar
MgMopar is offline   Reply With Quote
Old 04-29-2005, 03:38 PM   #4
use a silicon eater available from screwfix.......silicon will remove with ease,clean and re-seal
makaveli is offline   Reply With Quote
