-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Remove mould from white sealant? (http://www.diychatroom.com/f80/remove-mould-white-sealant-28229/)
kyodoc 05-15-2004 10:19 AM
I've got mould/green stuff growing on the white sealant which provides a seal between the edge of the bath and the tiles. I've tried using the standard bathroom cleaner and leaving it to soak in, but it doesn't work. Will I have to remove the sealant and re-seal it?
imported_Alan 07-08-2004 11:38 PM
Grotty Green stuff
Once this stuff is green she's hard to get back to white. Scrape it out and make sure you use a mold resistant silicon (Bath & Kitchen) most people fail to do this the first time round
MgMopar 07-31-2004 04:01 PM
bleach
I have found if the surfaces can handle it. Almost all bathroom tiles can. You can use straight chlorine bleach in a sprayer with caution. (bleach can be very harsh read labeling on bottle) and spray on the mold or mildew. Let this set for about two or three minutes and then thoroughly rinse. If it is indeed mold it should kill it and loosen it so regular cleaning methods should remove it. (Scotch bright, or green back of kitchen sponges work well but make sure it doesn't damage you finish).
MgMopar:cool:
makaveli 04-29-2005 02:38 PM
use a silicon eater available from screwfix.......silicon will remove with ease,clean and re-seal
