Remove And Cut Formica Countertops And Reuse. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 02:07 PM   #1
Remove and cut Formica Countertops and Reuse.
Cutting old formica countertops without chipping the formica. We want to reuse them in the garage in a different formation.
allens825 is offline   Reply With Quote
Old 02-25-2012, 02:14 PM   #2
Rewards Points: 13,712
Flip them over and cut from the back side. Cut the back splash firt then the main area. Lay a 1 X 6 along the cut line so the saws lifted up off the top so you will not have to tip the back to clear the front lip.
It's going to take two people, ones going to have to support the piece being cut off so it does not chip the top.
Since your cutting from the back side just about any # of teeth on the saw will cut it with out chipping. Just make sure it's sharp.
I would not use a plywood blade. It will heat up and start to wabble.
Old 02-25-2012, 02:24 PM   #3
Removal Formica and Cutting
Do you ever use tape along cut line to help prevent chipping?
Old 02-25-2012, 02:35 PM   #4
Can if you want to but I never use it.
The ciruler saw is cutting so it's trying to pulling the material up not forsing it down. So the formica is being pulled up againt the partical board so it should not chip.
Once the end cap goes on it's best to run a trim router over that area to round it off any way.
Just make a test cut and see what happens.
Old 03-01-2012, 09:15 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Yep. Step1 : Buy a finish blade.
CoconutPete is offline   Reply With Quote
Old 03-01-2012, 10:58 AM   #6
Civil Engineer
Rewards Points: 4,770
Best way to get a nice cut on formica is to use a router with a carbide tip laminate cutting blade. Perfectly smooth cut.
Daniel Holzman is online now   Reply With Quote
Old 03-01-2012, 11:04 AM   #7
How would that cut through a thick counter top?
Old 03-01-2012, 12:26 PM   #8
Rewards Points: 512
score it with an utility knife, tape, cut.
princelake is offline   Reply With Quote
