Remodeling Shower Stall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 08:40 AM   #1
remodeling shower stall
I'm in the process of putting up hardibacker boards in my downstairs shower stall. Can i get away with using 1/4 inch boards?! they seem pretty sturdy nailed in. ( Hoping i wont have trouble with the mortar and tiles) If so should i use a water proofing on these cement boards? Please i could use some help....thankyou scotty
scottyh63 is offline   Reply With Quote
Old 04-25-2012, 10:23 AM   #2
Work Hard, Play Harder
Rewards Points: 212
Yes, you HAVE to waterproof.
Hrm... start here: http://floorelf.com/answers
You cannot nail them in, and you can't use standard drywall screws. You need the specific cementous board screws because they have a different head to allow them to dig in and get flush.
Edit: I stand by ratherbefishing, you need 1/2".
coderguy is offline   Reply With Quote
Old 04-25-2012, 10:39 AM   #3
In a little over my head
Rewards Points: 706
I have never heard anyone say that 1/4" should be used on walls.
Besides, 1/2" will match up with your drywall better.
And yes. It must be waterproofed, either behind the wall, or under the tiles.
The floorelf wrote a great little book to get you started:
http://floorelf.com/waterproof-shower
ratherbefishing is offline   Reply With Quote
Old 04-25-2012, 11:16 AM   #4
i appreciate all the feed back, i needed to know since the salesperson for hardibacker didnt inform me about 1/4 or 1/2 inch boards..partly my fault also, i should have read up on this..thankyou everyone for helping..scotty
Old 04-25-2012, 07:28 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
NEVER use 1/4" inch on wall framing. That is for installation over subfloors.
Use 1/2"
- Build Well -
Old 04-27-2012, 08:30 PM   #6
Smile
Thank you will have to buy 1/2 boards and waterproofing.now when I put up cement boards w/ special cement screws. Normally with reg Sheetrock u spackle over screws or nails to smooth things out. But with this waterproofing would that take the place of spackle!? Then I would cover with mortar n tile!? After waterproofing is dry. Trying to follow right method.
retiling a shower stall grezut Remodeling 4 04-21-2011 05:16 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
How to properly seal window in tiled shower stall. Proby Kitchen & Bath Remodeling 0 07-21-2010 11:49 AM
How to build base for a shower stall atm Plumbing 13 05-13-2009 10:18 AM
Can I add a shower stall drain to my sink drain yardeningplus1 Plumbing 8 10-30-2008 07:04 AM
