Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 09-21-2010, 02:40 AM   #1
remodeling the shower
my bathroom is 32x32 and I would like to make it 32x60. Can I use a pre-fab pan?
mssally is offline   Reply With Quote
Old 09-21-2010, 07:01 AM   #2
I assume you mean the shower is 32x32, not the bathroom??? To install a larger shower base, you most likely need to make some framing changes. This often means stealing space from another room or closet.
Old 09-21-2010, 07:07 AM   #3
Super Moderator
Most standard pans are 36x60---you may be able to locate a 32----I suggest that you call a plumbing supply house---you may find that the service and prices are what you want.--Mike--
Old 09-21-2010, 09:24 PM   #4
Stuck in the 70's
Blondesense's Avatar
This will almost certainly involve moving the drain.
Old 10-26-2010, 08:47 AM   #5
Ultimatetouch
Remodeling the shower will involve some framing, moving the drain. You could use a preformed shower pan or go with a tile shower base. If you go with a tile shower base you should hire a bathroom remodeling contractor. The results will be much better. Preformed is simplethough.
ultimatetouch is offline   Reply With Quote
Old 01-09-2011, 12:53 AM   #6
Check out the 32x60 Kohler Salient receptor, I put in the larger model and really like it. Easy to clean with super durability.
hopes2 is offline   Reply With Quote
Old 01-09-2011, 01:09 PM   #7
You can find a wide variety of pans and shower enclosures online at lots of websites. Check out http://www.vanities123.com on the bathoom showers tab for a good selection or do a Google search for other sites.
Dreamline is one of the most popular manufactures of shower doors, shower enclosures and pans. They come in quite a few standard sizes and I believe 32x60 is one of the sizes.
DIYTom is offline   Reply With Quote
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Remodeling bathroom, shower fixture questions. HenryG Plumbing 11 02-09-2010 02:21 PM
Remodeling a walk-in shower Lyle Remodeling 16 12-04-2009 07:50 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Remodeling large bathroom shower showerredoer Remodeling 2 11-28-2008 11:50 AM
