Remodeling Kitchen And Bath - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 01:58 AM   #1
Remodeling Kitchen and Bath
I know that you can apply new formica over old formica after sanding, wipe off dust good, clean with alcohol, apply glue to counter and new mica. But if the edges are loose in places, do you remove old mica, sand down and reapply glue to edge of counter as well as new mica, of course. If not remove, what do?
2 threads on the same issue merged
Handymrs. is offline   Reply With Quote
Old 07-18-2010, 07:59 AM   #2
The substrate(plywood, or particleboard) must be sound, no rot(usually around the sink). And the existing laminate must be well bonded. If it has loose spots, it can sometime be reglued with heat/pressure. Otherwise, I would recommend starting from scratch.
The Following User Says Thank You to Just Bill For This Useful Post:
Handymrs. (07-18-2010)
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 11:51 AM
Retile kitchen and bath gmhammes Flooring 1 01-13-2010 03:02 PM
Adding a bath and Kitchen in the game room cprao Remodeling 4 12-31-2009 10:43 AM
Urgent help on leaking bath tub to kitchen surepan Plumbing 6 05-05-2008 06:39 AM
Bath entrance inside kitchen area rich121 General DIY Discussions 1 12-16-2007 06:44 PM
