Reinstalling Tub And New Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-11-2013, 09:44 AM   #1
reinstalling tub and new surround
Hi,
I had a problem with my water leaking through old tiles that surrounded my tub. I took down the tiles, removed the tub and cleaned and repaired the area under the tub. Now I am looking to put the tub back and install a new tub surround. One of those 5 or three piece surrounds. But I'm at a point where I need some help. The tub I have is a whirlpool drop in tub that was installed as an alcove tub. It was installed incorrectly with out the tile flange that was need for this installation. I've order the flange required straight from jacuzzi. But don't know what surround to get. The measurements for the tub is 35.75 inches by 59.75 inches. And then the way alcove it was sitting in before is in an odd configuration. It has the three usual sides, the far one was removed to get the tub out but will be reinstalled. But also has a 4 inch butt out corner where it meets the wall by the shower. I'll attach drawing of what I mean. That side is 36" long. I'm not sure of what I can do here, as all of the surrounds that I found that could fit it are 60" by 37". Should I cut out the wall more making it 37" or cut the surrond? But what should I do with the 4" corner? Should I scrap the tub and install a smaller tub, something like 60" by 30". Any suggestions would be great!!
Jonorato is offline   Reply With Quote
Old 10-15-2013, 05:19 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Can you attach a picture?
brockmiera is offline   Reply With Quote
Old 10-15-2013, 05:51 PM   #3
DIY staff
Rewards Points: 7,174
That's an odd opening---I doubt if you will be able to do a professional looking install of a fiberglass surround there.
Have you considered tile again? With proper waterproofing, the work will last for a long long time----
Old 10-15-2013, 06:14 PM   #4
Rewards Points: 13,472
I've never heard of an add on tub rim.
Real pictures would be a big help.
Old 10-15-2013, 06:23 PM   #5
DIY staff
Joe, these things are available---I don't trust them and have walked away from a couple of jobs when that was the only option---so I do not have any real world experience with the retrofit flanges.
In theory they work----
Old 10-15-2013, 06:56 PM   #6
Sort of like the older Anderson windows there where flat jambs and some funky vinyl strips with rubber seals on them instead of a proper nailing fin that all leaked.
Tags
bathroom , surround , tub , tub surround , tub surround question
