Redoing Backsplash With Stone, Tape Backerboard/drywall Joints? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By tribe_fan
  • 1 Post By thunder550
Old 01-30-2017, 05:57 PM   #1
Rewards Points: 14
Redoing backsplash with stone, tape backerboard/drywall joints?
I'm working on re-doing the backsplash in my kitchen. I tore out the old tile backsplash yesterday, which required taking out the drywall too, couldn't get the tile off without mangling the drywall. I'm putting ledger stone (the 6x24" strips) in as a replacement, which requires concrete backerboard.
I have the drywall cut even with the bottom edge of the cabinets and the top edge of the counter. When I put up the new Hardibacker, do I need to find a way to tape the horizontal joints here? I'm not sure how I would get the tape in behind the countertop or behind the lower edge of the cabinets.
Thanks!
Redoing backsplash with stone, tape backerboard/drywall joints?-pic.jpg
thunder550 is offline   Reply With Quote
Old 01-30-2017, 07:45 PM   #2
Rewards Points: 344
Re: Redoing backsplash with stone, tape backerboard/drywall joints?
I would not be worried about taping - but I would be tempted to toe nail in some nailers to support the backer on top and bottom.
jlhaslip likes this.
tribe_fan is offline   Reply With Quote
Old 01-30-2017, 07:55 PM   #3
firehawkmph's Avatar
Rewards Points: 1,902
Ditto. If you ever have to do it again. Leave about an 1 1/2" top and bottom to make it easy to tape in the cement board.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-30-2017, 09:49 PM   #4
Rewards Points: 14
I can do supports top and bottom, good idea. Thanks for the tip. I won't worry about taping.
One other thing...I had to cut out past the end of the cabinet/countertop behind the fridge. I haven't cut all the way to the next stud yet since I wasn't sure the best way to finish this part. Should I continue the cut to the next stud and patch with backer, maybe shimming the backer to make up the difference in thickness? Or should I stop the backer at the last stud before the end of the cabinets and sheetrock to the left of there behind the fridge?
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170130_203426617.jpg
Old 01-30-2017, 10:02 PM   #5
jlhaslip's Avatar
Rewards Points: 2,820
Another option would be to screw a backing piece of 2 x 4/6 at the end of the cut and another one at the end of the cement board. Drywall the spot behind the fridge and mud/tape the drywall.
*edit*
Also add backing along the horizontal drywall seams.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-03-2017, 10:00 PM   #6
Rewards Points: 14
Coming along...
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170203_103348230_hdr_1486180815314.jpg
Old 02-03-2017, 10:01 PM   #7
Rewards Points: 14
Starting on the stone tomorrow.
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170203_205921281_1486180866413.jpg
123pugsy likes this.
Old 02-04-2017, 05:23 PM   #8
Rewards Points: 14
Halfway done...
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170204_144627018_hdr_1486250574108.jpg
Old 02-04-2017, 06:40 PM   #9
Rewards Points: 14
Here's a better pic. I'm pretty happy with how it's turning out. Need to put a dimmer on the new under cabinet lights, man are they bright.
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170204_165553209_hdr_1486255207162.jpg
The Following User Says Thank You to thunder550 For This Useful Post:
123pugsy (02-05-2017)
Old 02-09-2017, 08:38 PM   #10
Rewards Points: 14
Got a chance to countersink one of the outlet covers tonight. Wasn't sure how it was going to turn out but I think it's pretty good.
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170209_193613_1486694300219.jpg
Old 02-11-2017, 05:30 PM   #11
Rewards Points: 14
Finished hanging the rest of the backsplash.
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170211_162921939_hdr_1486855840291.jpg
Old 02-11-2017, 05:32 PM   #12
Rewards Points: 14
I have about a 1/4" to 3/8" gap between the top of the stone and the bottom of the cabinets. Any suggestions on how to fill or finish this off?
Redoing backsplash with stone, tape backerboard/drywall joints?-img_20170211_162937344_hdr_1486855878462.jpg
Old 02-16-2017, 07:50 AM   #13
Rewards Points: 810
Tape off. Caulk the gap and rub on the stone dust. You can make the dust with hammer.
carpdad is offline   Reply With Quote
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Tape drywall joints before painting? mcraenz Drywall & Plaster 7 11-19-2009 06:28 PM
Can I tape joints on old masonite walls? ETD66SS Building & Construction 9 11-13-2009 05:09 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
